Overheating problem
Garry20VT
Hi I've gota 52 plate Cupra (not R) it's suddenly started overheating, if I keep it to 2000 revs it's fine at 90 degrees but take it upto 3000 or above and it shoots straight up to 120 degrees. The water level is fine no sign of any leaks external or into the oil. So I'm guessing it could be a thermostat problem.
Can anyone offer any advice, bit worried cos I'm working all day tomorrow then driving to Newcastle tomorrow night so need to sort it!
Garry
NickT
429
LB, Beds
As mentioned above, sounds like the water pump is on its way out.
I (and many others on here) have experienced exactly the same symptoms and it was the water pump.
Afraid it means a new water pump (metal impeller version although allegedly the OEM replacement has been updated with a better spec plastic one). Also get the cam belt (including new tensioner roller and tensioner) fitted while you are there.
As for your trip to Newky, I would look to getting a hire car I'm afraid.
Also meant to say, from what I've read on here, a faulty thermostat gives random fluctuating temperatures, usually between 0 to 90 degrees.
Garry20VT
Thanks lads, I was kinda hoping you weren't gonna say that!
Garry
freddie434
Yeh i have same problem keep it under 3500 revs n its fine yet give it some n thats it starts over heatin so jus slow back dwn again n goes back down to 90 degrees. Been 2 mechanic n they said could b 1 of 2 things, thermostat or blocked rad. They said if it was waterpump would b overheating straight away jus driving normally. Any advice, i got an idea what peps will say:cry:. Cheers
freddie434
How can i check rad is blocked? Not had the car long n was hoping for a reliable car bein part of VAG group!!
freddie434
Cheers for reply n info, any more common probs 2 look out for?
freddie434
sweet, well nice 1 4 that n ill get on 2 mechanic n get water pump changed, cheers
freddie434
They have been changed been changed 10,000 miles ago so would they need doin as well or not, i no you shouldnt put a used belt back on but wat bout tensioners n rollers?
freddie434
Getting my waterpump n cam belt dne 2moz and all for £180, mates rates are sweet!!! so hopefully this over heating problem is solved. Fingers crossed!!!
