Painting engine bay plastics
Trublu07
1,334
Essex
Does anyone use any special paints/laquer for painting the 3 plastic engine covers or are normal Halfords spray cans ok. Bit concerned they will react to the heat.
cupra_mike
861
id suggest going over with heat resistant paint first then give a few coats of the colour you want then clear laquer
dan boy
198
loughborough
use plastic cleaner to get the crap off then use plastic primer so the top coat does not crack when flexed and then just paint as normal and laquer did mine same coulor as body 2 years ago and still looks like new ..you can get all the stuff from local body supliers i used hex holdings for all mine and got the top mixed by them as well :D
Trublu07
1,334
Essex
For the engine cover do I need to use any special sort of hi temp glue to stick the insert back in?
Trublu07
1,334
Essex
Superglue won't melt? I don't want a fire in the bay with all that paint and laquer. I have noticed a run on the engine cover now I have finished it but can't be sears to re sand
SalSheikh
Under the Hood
Sep 2, 2009
2,760
Midlands, UK
oops, try no nails then or sticks like sh*t from screwfix, it really does exactly what is says on the tube! dont get it on your fingers as its a bugger to remove/wear off - i have the t-shirt lol!
tbh, most bonding materials will do the job as the cover wont get that hot
Trublu07
1,334
Essex
Lol ok cheers dude. Are you with your car? If so could I be cheeky and ask a favor. I need a pic of the rear pads against the rear discs showing the amount of left. . Could you help us out?
