Panel Filter
Jimmy8681
I thinking of buying a panel filter for my 1.2 ibiza. Can i use one with out upgrading my exhaust. I have been told by friend with a modified corsa i need to upgrade my exhaust for the panel filter to work. Can some help me
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
I don't see a problem with just getting a filter as long as it's not dripping with MAF fouling oil
go for the non MAF fouling green cotton filter
most engine performance mods will work quite well by themselves, if you want to go all the way it's up to you
go for it and get the zorst later if you want to ;)
gazjones
its incased in the engine cover on the 1.2 so you have to pull that off then there are screws underneath holding the housing to the cover
Jimmy8681
can tell me the best way to get the engine cover so i don't brake anything (Is the cover will have the engine type on top of it, The Black thing in the middle)
gazjones
they are attached with rubber bungs just pull it upwards will be tight but will come off!
