chris285
leon mk1 fr tdi
Nov 26, 2004
1,849
lincoln, uk
my parcel shelf is only connected on one side via the tie support, i am missing the little plug that goes into the hole on the rear frame that you put the end of the cable support onto
where can i get a replacement as i have had a look round but haven't been able to find one, would like to try and get it sorted before the national meet as well :p
thinking about replacing the faded red on the fr stickers on the side, probably need a new one to replace though but not sure on about the best way of removing the old one and the best way to attach a new one
The old badges will come off with a bit of tooth floss. Cut through the sticky foam backing then use WD40 / GT85 / Petrol to clean up the residue. The new badges will come with a new sticky back. Put a couple of clear coats of lacquer on the badges before fitting. They will last longer.
You can order the badges and pin from dealers on here. Will save you a trip. Ted Johnson, Sere Motors etc...
