Park assist/park pilot and rear camera retrofit
mos3ab
11
Hello,
I'm new here so sorry for any missing informations.
I bought a used a 2021 seat leon mk4 style. It has no parking sensors what so ever, i'm thinking about retrofitting park pilot or park assist and rear camera from kufatec or k-electronic.
My questions are:
1- is it would be doable for my car?
2- If it's doable i think i need PR codes for bumpers, infotainment unit etc for compatibility, which i didn't find the sticker anywhere in the car, erwin was a failure after one hour subscription hahaha, the local dealer here said he dosent provide this "service" which is hilarious, i emailed the official seat in my country, but no response, i searched google for any PR code source from VIN but no luck, i don't know if there is a way.
Thank you
cairus
1,677
589
I retrofit a lot, and the quality of kufatec is bad, wrongly pinned. General material quality, everything the same color etc. The cable sets from the Far East are top quality, mostly OEM color, great support etc. I only buy from the Far East
Reactions: mos3ab
mos3ab
11
Why should I buy in Europe when the dealer from the East can do better, has more OEM, and is significantly cheaper?
Yes, i guess it is understandable for you since you retrofit a lot, for me i thought differently maybe because i don't think i know who is trustworthy with coding controle units etc in my country, the link you sent me i remeber sending it to someone who do retrofitting and VAG coding, and he gave me a vague response about checking the part number for the aliExpress park pilot which i couldn't find, that's why i thought maybe european vendors would be moe clear about technicals specifications eventhough they are more expensive, i'm really feeling lost, and afraid of buying things that would't work ???
serdar_18fr
671
Hello,
My questions are:
Thank you
Look at the kits below, by original SEAT Accessories website.
Part numbers are available on those pages.
Using those numbers, ordering them via a SEAT dealer or a spare parts importer should not be a problem, I guess.
This may be the easiest & safest way to add parking sensors to your car.
Installation guides are also available there.
One side note: As you may already know, in the infotainment unit, there's a visual depiction of parking process. Some coding would be needed to activate it after you installed the parking sensors.
Reactions: mos3ab
mos3ab
11
Thank you for the effort, i have tried asking seat local dealer for these part, the answer was: we do not import these accessories and we do not install them, i looked for other shops who kinda do retrofitting here bit they won't chech compatibility for me, i have to bring my own part under my own responsibility
serdar_18fr
671
There's no risk of incompatibility with these kits. They are listed on their own accessories website under Leon 2020-2025 model. Only thing you need is to find a competent technician who is familiar with the VAG cars, their electrical systems, connectors etc.
Sent from my 23113RKC6G using Tapatalk
Reactions: mos3ab
mos3ab
11
Than you for your effort and time, and activating optical visualisation on screen with these kits would be possible you think ?
serdar_18fr
671
Most probably it would be possible but I can't say yes for sure. I don't know how much buying these would cost you but I would take my chances if I were in your situation. You might do some research to see if somebody has done something like this before. A lot of coding would be required for sure, on a lot of modules such as gateway, infotainment, instrument cluster, pdc itself and maybe a couple of more units.
Reactions: mos3ab
mos3ab
11
I will see what i can find, thank you
