It delays it so that if you have to wiggle around to get in a tight space, the screen isn't going on and off whenever you go in and out of reverse. Passenger mirror lowering works on the same basis.Activated parkpilot display with vcds short while ago, everything is working except 1 thing. It doesn't get off the display once taken out reverse gear. There is a massive delay, im wondering if a setting is available to alter delay time
Sent from my SM-G930F using Tapatalk
Also strange that some people don't have either a Parking Aid button or the ParkPilot display enabled as standard on an FR spec. Must have cut back on the spec of the facelift - what you give with one hand you take with another!
SEAT dropped the front parking sensors pre-facelift in early 2016. My FR was built a few weeks after this, and therefore didn't get them. Coming from a Focus Titanium with all the parking toys, it was hard to get used to rear sensors only and just beeps to tell you if anything's in the way!
There's a company that retrofits them and gives you the ParkPilot. I would get this done tomorrow, but not at the cost of over £600, that's just crazy. Especially as it only costs £165 as an option in the first place. I know there's some work involved in doing the retrofit, and it's easy to do it at the build stage, but......
I’m the same as you rear sensors only but I turned park pilot on through obdeleven, if you were interested in getting it back that is!
