Parking lights/drl lights
Oct 31, 2023
12
Hi guys,
Please can anyone help me with this one ... What should i do to do it right like the left side .... I dont want it with headlights on ... Can anyone help me please guys...
I would really appreciate some help...
Oct 31, 2023
12
tracktoy
812
661
OK did you use One Click Apps or do manual coding.
Did you do a full backup before you started coding, if not can you do a backup of your lights and share it and I will compare vs some backups I have.
Reactions: SteveGSXR600K1
Oct 31, 2023
12
No I did it manual coding. And no I didn't do any backup at all... I wasn't thinking about it ... It was a long time ago ...
Do you mean if I can do a backup as it is right now?
tracktoy
812
661
Yes you can do a full backup of your car https://support.obdeleven.com/en/articles/5608805-full-backup-android
or you can just backup the control unit for you lights https://support.obdeleven.com/en/articles/5627084-backup-of-control-unit
You can also share your change history https://support.obdeleven.com/en/articles/5608821-car-history
tracktoy
812
661
This is a nice simple lighting channel picture so you can see what the name of the channel you are looking for (eg Leuchte etc)
So if you go to control unit 09 and then filter you history to show Adaptation changes only (there is an upside down triangle on the screen that shows you what you can filter by) you should be able to find what you did.
Just to be clear the history shows you what you started with and what you changed it to so that you can then reverse that change.
Hope that helps.
Reactions: Walone
tracktoy
812
661
If you are having problems, just go control unit 09 and email a copy of your history and share that with me and I will have a look to see what needs changing
Reactions: albanjashari
Oct 31, 2023
12
I dont know if it' this one I have to change ... Because it only appear when I turn off the auto lights and then when I turn the light to parking lights that's when the headlight turn on on the drivers side ...
tracktoy
812
661
OK They all match up to my settings but there are other settings in Leuchte2SL VLB10 can you share all the settings and can you also share the settings for the headlight that comes on (is it the dipped beam or full beam) as you may have made a change there.
Oct 31, 2023
12
I think it's dipped beam I have been touching. Its only on the drivers side.
Oct 31, 2023
12
I will show later today when I have the car nearby me.
tracktoy
812
661
no rush, if its easier just do a backup of control unit 09 and send that to me (I will message you an email address ) and I can do a quick compare to my setup and tell you whats different.
Reactions: Walone
LeylandVCDS
579
348
Leyland, Lancashire
Here is an relevant adaptation map of the 09 control unit for a Leon with factory LED headlights and DRLs. Compare the values of the lighting to yours, and change accordingly. This adaptation map is factory accurate so if you match these values you should get things as they should be again
Leuchte 2 and 4 are the left DRL channels
Leuchte 6 is the left dipped headlight
Leuchte 8 is the left main beam headlight
Leuchte 3 and 5 are the right DRL channels
Leuchte 7 is the right dipped beam headlight
Leuchte 9 is the right main beam headlight
12
Leuchte 7 is the right dipped headlight
So if I do this, it would work? It should go back as before?
