Hi, does anyone know the OEM part numbers for the ST exhaust across the 280, 290, and 300? I am trying to work out if the OEM exhaust is exactly the same on all 3 variants (ie. has the same part number). Thanks.
Do you want assembly numbers? Or individual part no?
In a nutshell the 280 & (old)290 will be the same.
The 300 has the option for the haldex so that will be different, As the centre res has to allow for the driveshaft.
The new 290 has no centre but instead the gpf, so that will be a different part no.
However it would be safe to assume the back boxes have not changed....
