Passenger side window not working??
TalVito
40
couple of nights ago I forgot the window a little open,
some rain found it's way in behind the door card i guess,
since then, the switch is not working, but from the driver door I can play with the window,
any ideas? could it be the switch? the fuse? the wire harness?
:shrug:
Curtly
893
19
Essex
Switch is bust, happened on my old car. You'll be hard pressed to get it done under warranty unless you somehow try to blame the way that water falls from the roof directly on it when the window is open and you first move it.
On an additional note guys, if water does land from the roof onto the switch then dry it off asap - don't let it have time to sink into the electronics
TalVito
40
try and pin it on warranty :)
so just the switch you say?
someone has the part number maybe?
