on a sustained spirited run during the summer my oil temps reached 120 degrees
which is a tad concerning......
IIRC the standand setup on a PD130 engine has an oil cooler at the base of the oil filter.
Is there an upgrade / possible swap from another VAG car that's a bigger cooler and also a direct fit that i could use to help regulate the oil temp a bit better?
which is a tad concerning......IIRC the standand setup on a PD130 engine has an oil cooler at the base of the oil filter.
.......Jason....the sandwich plate you have fitted, is that a universal item? got a link
