crookiecrook
23
hi guys
i had the headgasket, cambelt , waterpump the other month and notice that oil was leaking and it seems to be getting worse. like i filled it up on monday and last night i had to top it back up again as it was just touching the dip stick.
ive changed the rocker cover gasket which didnt make no differnce.
the oil is coming from the back of the engine more so on the gearbox side, and a bit on the front from the same side.
anyone got any ideas?
Try steam cleaning the engine and running it through various revs and have a good look around the engine.
If nothing is obvious. Take it back to the garage who did the work and get them to compression test the cylinders and sniff test the coolant.
Also get them to re-torque the head bolts!
