Its all down to the tuner, to get over 200bhp it needs time and a bit of fine tu ning.
i use the same RR for all my mods. When i had allards turbo and mapping my car produced only 198bhp, i since took off the turbo( as it was faulty) and put a turbodynamics stage 2 on and had chipped IRE ( chipped UK) to do the fine tuning, he sent me the files by email and i used a ecu flasher to upload.
My car now produces a smooth 220bhp with hardly any smoke, and yes the RR is accurate, octy1 vrs were producing 179bhp-183bhp and when i had revo it produced 170bhp which was spot on all on the same rr.
@redcupra if you car is producing 215bhp on standard turbo it wont be long before your turbo pops again.
ps Devonmikey has some PD160 injectors for sale from his old one, if you are after some
If i look in ETOS for the partnumbers then they are both the same.
But now my tuner claims that the PD160 has different injectors.
It's hard to get my ibiza FR tdi over 200hp even with all my mods and this doesn't seem right to me.
What do you guys think about it...are they the same or not?
Never checked, which logs on vagcom would tell? A lot of my map is based on timing adjustments etc, also done a camshaft retard. I believe some maps( i wont mention) are just fuel dumps and boost.
The head mapper (miguel) is over towards the later part of this week iirc, so they will have a look at them, and decide what can be done
Shame it's not next week as I am going down there then![]()
I also want my map changed as I think there is more to come(not runing much more boost the standard chip)
I am popping up on tuesday to check on my Audi. When you going ?
My tuner is still perfecting the map.They got for now215hp and 332lbs/ft out of it![]()
That's better![]()
I need to work on my torque![]()
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
i need to wok on fecking everything![]()
also done vag com logging and actual boost was just 1.6-1.65 bar. and i get hardly any black smoke in fact Flashbsd said a standard cupra tdi smoked more than mine.
