to make it sound beter you want a bsack box just before the tip if you hav a center section as the sound vibrates thru the pipe to the exit you get a **** sound
i would advise the back muffler back as close to the exit as possible should give you a nice meaty grawl without to much shout
and belive me wen i say the pd170 is loud without any silencers i did it for around 10 mins and andrewjb had his done with no baffle and its just to much its silly loud so i would stay away from teh no box idea
something a bit like this?? also with no centre section
plus had half the sound insulating material removed from the box, it’s a good mix between noisy and bloody ridiculous (like Andrews). Also putting the rear seats down make a big difference (good for on track:))
Your next mod should be selling your old headlights to me on the cheap so I can have a go at some projector conversions! ;)
Going to do a retrofit myself when i get some time! =]
Cant wwait though, sorry mate^^
Down pipe?
Thought about it, but changing the downpipe will probably fail MOT as it would be "modified" So leads to a big no =[
Spray/wrap heater and stereo surrounds
Would like to do this but again time consuming =[
Although maybe look into it in the future :p
What's the power/torque by the way?
Power im guessing around 210 bhp and around 300lb ft Torque
(Dyno day with cupranet soon, end of the month, Will post sheet up then^^)
You only have cat back don't you?
3 inch down pipe and decat
Again 3" downpipe might lead to MOT Failure, and theres no Cat, i got a DPF instead which is non existant.
BOV=No
CAI=No
Sent from my GT-I9100 using Tapatalk 2
Any idea why mate?
No performance gains?
Just noise?
Let me know =]
Thanks for input guys,
Really appreciate it
Any idea why mate?
Just noise?
Let me know =]
BOV = CHAV sound on a diesel and you will loose more power than you gain as the turbo has to recompress all the air it just vented again so probably create some more turbo lag
as for the CAI ther is mayb a slight increse but not in top end power just that the turbo can mayb spool a little qwicker
still is somthing to just look nice and cost £ rather than do anything amazing
if you want to make a propa mod to your cold air intake then get an S3 all alloy intercooler
Really thinking about buying a carbonio intake for the pd170 ^^
I fancy a darth vader passenger haha
Anyone selling one cheap?
it wont increse power but if its just for looks thats cool :) i was thinking bout somthing just to make under teh bonet look a bit more impressive than just plastic all over
I cant remember where but i read that these things give noise?
Reason why i dont want an open cone is because it will suck in hot air which leads to performance loss =/
Looking good mate! Just an idea bt wot about some lite weight alloys in black to keep your current look and also help with performance?
Still trying to source a cheap shortshifter and maybe a filter which adds noise & performance!
Anyone suggest anything?
filter wont add performance if the engine is requesting the turbo to make 26psi boost and its making 26psi of boost then an uprated filter is goin to make the turbo run at 27psi ther is 99% nothing to make ther is a slight chance the turbo could spool a little faster but this again is controlled by the ecu and vnt position
save money on the filter and get a forge short shift :)
your main problem is you hav bought a diesel and petrol rules dont apply
What can i do in terms of upgrade performance then?
I think i am happy with the exterior mods, just want to change the performance slightly without big ££££s
Shortshifter im definatly buying its just trying to find the best place to buy?
Any links available?
Let me know
Thanks for input!
Let me know
Thanks for input!
to be honest your about ther anymore and you will need a bigger turbo to push more boost
what is your current dyno print out and who did the mapping ? 210bhp ?
