Pyro
As most of you know I've got more boost leaks then I can poke a stick at
lol my question does the leak effect peak boost or should it peak then drop
At the moment it peaks at 17 drops to 10 and as far as I'm awere stage 2 boost should be around the 21-24 mark
Also will the ecu pull the boost back if it's leaking? Coz when I turn it up with sp3 switch it doesn't change at all
