graemebillo
126
34
liverpool
Hi all.
Just looking for a bit of direction on this one.
67 plate cupra 300. About 68k miles on the clock.
I've noticed over the last few weeks that I get the occasional smell of petrol through the front vents.
Seems to be more idle and possibly more so when the A/C is on.
Although I can't quite narrow it down yet.
Had MOT a month or so ago and a recent major service, although not an official dealer one.
I was just wondering if anyone could shed any light in what I could be looking at.
Not noticed any extra use of fuel or wet patches below the car.
Performance seems to be OK too, although I have been using e10 fuel for a little while due to having sold all of my internal organs to pay for the previous tanks of petrol .
Curious on where to look really, as have seen some people mention about the pollon filters or blocked vents at the top of the dash.
Any thoughts would be amazing as ever.
Thanks in advance.
Could be either exhaust leak or petrol leak with one of the hoses. I made a video on how to replace the fuel feed hose, it's quite easy to inspect it. Pinch the hose near the fuel rail and see if it leaks any petrol on the connection (on top of the high pressure fuel pump).
If you also have the secondary port injectors, there is another fuel feed hose from the side of the high pressure fuel pump to the secondary fuel rail
[edit]
If you have the fuel feed hose which consists of 2 pieces, I highly recommend you replace it with the latest revision. The old partnrs were known to crumble from the inside, which would clog up the injectors and could cause catastrophic engine failure!
That's amazing.
Cheers. Guess I know what I'll be doing at the weekend.
Thanks again.
Will keep you updated if I find anything incase it helps others too.
Sent from my 25113PN0EG using Tapatalk
Reactions: nd-photo.nl
