Pew's mk4 Ibiza Cupra.
Pew.
1,436
138
Scotland
Nah i wont be at that, already have plans :|
Bought a headunit yesterday :)
It arrived this morning :|
Pew.
1,436
138
Scotland
Headunit fitted, went straight in no adapter or anything needed. For now i have just crammed the DAB arial in behind the headunit, still gets a good signal but will be moving it to a better place on the weekend.
Pew.
1,436
138
Scotland
Routed the dab aerial today from the headunit to the drivers door, up the rubber seal to to roof lining then along to where middle of the windscreen. Perfect dab signal with no interference and I can hardly see the aerial :)
Sent from my XT910 using Tapatalk 2
Pew.
1,436
138
Scotland
Serviced the forge 007 valve today. New piston, seals and spring (green)
Old seals, piston and spring out
New ones :)
All cleaned up
Built back up
And back together :)
Pew.
1,436
138
Scotland
Not very good pics but you get the idea of what the DAB aerial looks like and how I've ran it
Up the door pillar and into the headlining
Out of the headlining in the centre of the windscreen (above the rear view mirror)
Its a small black plastic thing, about an inch wide with 2 long clear strips with a wire inside from each end
Can't see it at all when driving.
I have also moved the headunit down to right above the climate control and moved the holder part up to remove the gap that was left.
Pew.
1,436
138
Scotland
Some more goodies arrived today
And rear bulbs :)
This will shortly be filled with music and left plugged into the headunit
And here's a sad dog in a sock
Pew.
1,436
138
Scotland
Replaced front arb bushes today. Easy job but fiddly as ****
Pew.
1,436
138
Scotland
I hate you, you could have given me a heads up lol
Drivers side was fine, fiddly but fine.
Passenger side sucked. Gearbox was in the way so couldn't get the ratchet, had to use a spanner that took ages to get the nuts out lol
Pew.
1,436
138
Scotland
Gearbox oil changed today, noise practically gone, only drove a few miles with it so far though.
These arrives today
