Very good price, I leased mine for £131 a month so was more than happy with that, now got a B9 S4 for £280 a month but always said I'd go back to a Cupra at some point for a 2nd carThankfully I'm one of those.![]()
I was lucky enough to have a lump some of money to buy a car and was extremely close to buying a Mégane RS trophy until I found out you could get a Cupra For so little.Very good price, I leased mine for £131 a month so was more than happy with that
From what he's saying his dash dials are reading when above 50 but the main screen dials still aren't reading after thatThe reason you have the “dash” in the sport dials is because it is too low a temperature to tell you. Same happens on mine it only shows a temperature I think after 50°c which takes a good 10 minutes of driving.
Ah okay. Weird one. Possibly swipe them up/ down to change them around then swipe back through to them see if it jogs it to update.From what he's saying his dash dials are reading when above 50 but the main screen dials still aren't reading after that
Gearbox needs to be in S to get the louder up shift dsg farts
As @Kirky has said, look in the boot for this![]()
If you look at the picture I posted of the Sub in the boot you can see my sticker on the left
If you then go to this link, you can decipher the codes on the original car build
http://vag-codes.info/files/options/vag-option-codes.pdf
Sorry yes, manual in the dsg is basically sport but you do the shifts so you will get the farts at the correct rpmSo it doesn't do it at all in manual mode?
Definitely shouldn't be that much travel in it
This isn't right. Even in comfort I don't need much movement of the pedal.Is it just me or does the accelerator pedal have quite alot of travel before anything happens while driving (In any setup), I can pump the pedal probably not far off half way down while coasting and the revs don't move.
Revving it in park seems to react alot higher up the pedal though.
Not right that, mine is almost instant in any mode.Is it just me or does the accelerator pedal have quite alot of travel before anything happens while driving (In any setup), I can pump the pedal probably not far off half way down while coasting and the revs don't move.
