I must admit to using resistors for the Number plate SMD bulbs.
Pics when it's dark
The rear LED brightness is found in cent elec, coding, then use the drop down menu for the voltage 12.3 for min and 13.6 for max IIRC It does make them quite a bit brighter.
Same with the DRL's too
You can also up the brightness of the xenons but I didn't bother as I don't want to blind people.
I think you can disable bulb cold diagnostics with VCDS, this turns off all bulb failure wanrnings though.
Welcome to the candy white club looking very Mint I would have loved a supercopa but the pennys wouldn't allow it :-/ also thanks for Link to DRL I'll get them ordered
Looks sweet Nath. There not the standard Supercopa alloys are they? I have a set of those in the garage 'diamond cut' version and was thinking about popping them back on. - look good
