Pyro
Ape your photos are fantastic! You do photography or something?
Stop your flirting booya
Few pics of mine on the coilies!
Got a different front numberplate now though, 3/4 size one so the fmic gets more cold air
Didn't want it too low for practicality reasons..
just need some spacers on now tomthat drops spot on
Loving the pics of these LCR, however just want to ask, do you have problems with it lowered? For example, I've got a LCR 225, it's on standard suspension. Had two new front tyres yesterday and laser alignment and the car only just got on the ramp, the front missed by about 20mm!!!
I know what you mean how can you stop it tho???
Cheers Wayne. Yeah spacers are defo needed now! Any recommendations?
Think 10mm on front an 15mm on the rear, or 15 front and rear! Thoughts?
hold on, make sure you know what you are getting with a 40/50mm kit.
that measurement is from the standard height for a leon, and is actually going to be about a 20/30mm drop for a LCR as the LCR is about 20mm lower than a stock leon.
for example, sambryant's leon has been dropped about 20mm, which represents a 40/40mm kit but is much higher than APE's leon which he says has been dropped about the same as a 40/50mm kit. - i suspect APE's has been dropped 40/50mm from the LCR height as his leon is way lower than sambryants..
or compare bakes100's to APE's they are worlds apart in terms of drop.
Bakes100 being a 50/40 drop and i would say is representative of what you would get with a 50/40mm spring/shock set up.
hope this makes sense.
If you stick 20mm on the front, the front wheels will stick out further than the rears. 15mm back and 10mm front about balances it all out. It's my opinion but I think that 20mm on the back looks odd.
I will be selling my 10mm H&Rs soon in favour of some 5mm for the front.
i ve got 20 mm back 10 on front but sold the 10s and want 15or 20 on front now look at lee69 he running 20mm all wrond looks good.![]()
You can't stop it but some spacers will make it looked better. Some 15mm on the back abd 5mm or 10mm on the front
Looking good, Tom. That's the look I am after.
The nose is so far forward from the front wheels so the overhang coming off driveways can be a pain!
Been thinking of lowering for a while then I'll go somewhere and see how low the front gets and change my mind!!!
