Feb 1, 2010
987
Leicester
hi i am putting a avic f900bt pioneer sat nav unit in my mk2 leon and i want to keep using the oem bluetooth system not the one built in the headunit!.
Does abyone know if this is possible and does it still mute audio if it is set up like this.
Thanks in advance
Thanks in advance
THe OEM one will work just the same I would of thought but it will not mute the pioneer unit unless pioneer to a canbus interface. You may find the pioneer bluetooth works better as it will display everything on the screen.
Out of interest why the PIoneer and not the SEAT OEM RNS510 Sat Nav that you can pick up for £600 and will work with your existing bluetooth?
THe OEM one will work just the same I would of thought but it will not mute the pioneer unit unless pioneer to a canbus interface. You may find the pioneer bluetooth works better as it will display everything on the screen. Out of interest why the PIoneer and not the SEAT OEM RNS510 Sat Nav that you can pick up for £600 and will work with your existing bluetooth?
never really thought of it to be honest. I got the pioneer on a half price offer for 400 quid. I had a bluetooth pioneer last car i had and was fine i just like the voice dialling from the wheel.
I am using the canbus interface and pioneer patch lead. Looks like a hell of a lot of wiring looms to hide though!:confused:
yes mate my oem bluetooth works fine , no doesnt mute the pioneer , you have to select phone from the headunits source button , but you get used to it.
ok so when you receive a call whilst listening to a cd does it not turn off the cd?
had the unit fitted today and now the oem does not work. it does operate and still says insert phone and i can still connect my phone to it. but no noise from it!![:@]:censored::censored
the fitter reckons it does not work as the oem bit is built into the standard headunit.
I am not happy but i can still use the pioneer system,
Also the sticky magnetic pad that holds the gps antenna down has come off already!!
sorry about the rant ,
