Steveo_Hants
Still having major problems with my rear doors. They have been stuck locked now for ages so i thought I'd best do something about it. Managed to get the door card off and replaced the central locking motor and the actual lock. Put it all back together and it still doesn't work! You can now open that rear door from the inside (couldn't even do that before) but it still doesn't unlock on the central locking! Driving me mad![:@]
I have been told it could be a fault with a module in the drivers door not sending a signal to the rear doors.
Anyone help on this? I have booked it in to the "stealers" for Monday but don't want to pay them a fortune if I can help it!
On a transit i had, i had simialr probelm and all it was a metal hook had fell out of the door realse inside! might be this easy! it just looks like a coat hanger going to the bottom of the door handle it was just a matter of pushing back in!
Right, come out of work tonight and the door we replaced the lock and motor in didn't open on central locking, so I unlocked it from inside and then locked and unlocked with key fob and the door locks and unlocks, its almost as its really stiff and the motor can't manage to unlock it until its been freed up manually. The other side still doesn't work at all and can't open from inside. Going to have to do some more investigating!
if the motor is getting power tho id of thought that means the wiring is ok
check the fixing for the motor, it might be ill placed which is causing it not to be at the right angle to operate the locking
