poly bushe's. ..
scott180
434
portsmouth
andy68
106
TAMESIDE
Dogbone is right, Top mount looks ok, seem to be similar to the Red Polybush that some people had problems with fitting due to the top mount cups sitting high so then they used Polo ones which sometimes pulled through the strut hole, hopefully Powerflex have cured that.
scott180
434
portsmouth
Thanks for the reply. Got told the yellow dogbone won't make any difference from standard :/ apparently these top mounts have replacement top caps as I have the gap at the moment. Suppose thee is only one way to find out.
Ash-Kennard
why are you reading this?
Jul 31, 2008
286
portsmouth
Hello Scott,
I am going yellow big end on dog bone and black on small end. Should be fitted in the next couple of weeks.
Top mounts, I couldn't tell you.
FandangoDanby
18
I had the power flex dogbone mounts on my car done years ago and I've never looked back, it does make a difference and it's a worthwhile upgrade.
scott180
434
portsmouth
I've had the polyflex purple top mounts fitted and they seem to be fine. Slight gap under top caps but apart from that it's brilliant. Dogbone I think I'll tackle tonight :)
