auzo63
17
During the heavy rains yesterday on the M40 my Altea became very unhappy:(
The traction control light came on and the car started to judder.
After turning the ignition off then back on it cleared for a short while, but then came back.
I have the following fault codes but have no clue what they mean?
P1116 - 009 Oxygen (Lambda) Sensor Heating: B1 S1 Open Circuit
P1117 - 07 Oxygen (Lambda) Sensor Heating: B1 S2 Short To Ground
P1342 - 006 Ignition Coil Power Output Stage 1 Short To Plus - Intermittent
P1344 - 006 Ignition Coil Power Output Stage 2 Short To Plus - Intermittent
Check the water drain holes for the windscreen lower panel, the ecu and wiring connectors are behind there, could be getting flooded during heavy rain. Mine were totally glogged with leaf debris when I bought my car.
Paul_Treg
Paul_Treg
Checked the Drain Holes and all clear
Update
Don't want to speak too soon but all seems ok now it is dry so will have to wait for the next summer storm!
