Pre GPF downpipe on GPF ST
Apr 16, 2023
Hi, my car is completely stock right now and I was thinking of swapping the stock downpipe on my 2019 300 ST GPF to a pre GPF downpipe. Considering the car is stock, will i run into any problems such as backpressure with the turbo or anything else? Has anyone done it and if so is it a big job to do? Also wondering if this will fail MOT. I'm aware that I need to map out the GPF when removing it. Thanks in advance every answer will be very much appreciated.
Damo H
4,707
2,817
Car Length In Front
You'll likely need the GPFs coded out via an updated MAP, although not 100% on that.
As for failing MOT, its a visual inspection only, so it would only fail if they know its meant to have a GPF fitted. So depends on how competent or thorough your MOT inspector is :D
