Aug 18, 2026
Greetings,
so, to start, we bought the car 2 years ago, didnt like the sound, emptied the mufflers. Wasn't enough, we took out GPF/OPF and mapped it. All was well, till about half a year back, when she started drinkin gas like there's no tomorrow, goin from 21mpg to 15mpg over night. We changed the PCV valve with a knock off and it worked till a week back, when she started doin it again. Now, wwe changed it with an OE but things are not well. She's got high idle (like she's always in coldstart), does about 14mpg.
We took it to a local shop, checked and there's no active GPF regeneration (had to check, even if she's got no GPF), no fault codes, no nothing.
My question, what could possibly be wrong, before we take her to 4 more shops and no results...
Thank you so much in advance.
Hey, thank you, will mention it and check. Lamda should put out a code, no?
No, nothing else was added, other than 63 ornamental cats all over dash and rearview mirror.. :)
Greetings,
First thing i would look for is an intake leak. That can cause high idle and wouldn't throw a code. If you have a smoke tester then i would smoke test, if not then just visual inspection
Reactions: vozlov
Looking at intake manifold mostly, or where?
Thank you!
Using VCDS, you can check measuring blocks to see if the lambda is doing something.
https://www.ross-tech.com/vag-com/m_blocks/030-049.html
Someone mentioned here not to long ago a weird situation where the 2nd lambda sensor was requesting 100% fuelling all the time, could also be the case who knows.
Might be handy to know your mileage?
I would also look/log your temp sensors to make sure they are doing something meaningful.
Agree on Lambda sensors, they only have a finite life typically 60-100k miles - and can be damaged by contamination/thermal shock/Rich running.
Hey guys, a little update. I called around and got me a specialist who can take a look with vcds next week, but I've managed to get a reading of lambdas at MOT and they are fine (MOT wise, could still be defect). We pressure tested intake and no leaks, no new codes, so till next week, I know nothing.
Thank you again for your opinions and instructions!
Reactions: nd-photo.nl
