Aug 18, 2026
Greetings,
so, to start, we bought the car 2 years ago, didnt like the sound, emptied the mufflers. Wasn't enough, we took out GPF/OPF and mapped it. All was well, till about half a year back, when she started drinkin gas like there's no tomorrow, goin from 21mpg to 15mpg over night. We changed the PCV valve with a knock off and it worked till a week back, when she started doin it again. Now, wwe changed it with an OE but things are not well. She's got high idle (like she's always in coldstart), does about 14mpg.
We took it to a local shop, checked and there's no active GPF regeneration (had to check, even if she's got no GPF), no fault codes, no nothing.
My question, what could possibly be wrong, before we take her to 4 more shops and no results...
Thank you so much in advance.
Greetings,
First thing i would look for is an intake leak. That can cause high idle and wouldn't throw a code. If you have a smoke tester then i would smoke test, if not then just visual inspection
Reactions: vozlov
Looking at intake manifold mostly, or where?
Thank you!
