tris
The Daddy
Feb 25, 2005
3,492
Kent & Track Days
www.leoncupra.net
Since putting a Nokia handsfree kit in i have no radio signal but did have before
I have had a look though some threads and have seen that it may need a ariel booster
But before i buy one i wanted to ask if anyone else had this problem after putting a handsfree kit in
must be a loose areal wire! or the bluetooth is cutting off the sound!
Check your wiring! One by one
That sounds like the power leads are round the wrong way on the HF kit...had similar problem in an old car, because it stays live all the time it just disconnects once out of range, and then won't re-connect when you get back to the car.
The only thing thats left is that box that puts the Handsfree speaker output through your stereo speakers...
Other than that I'm stumped about the radio signal.
I even tucked that booster right out the way when I put everything back in situ, to try to avoid as much interference as possible.
Its finding the time but will pop along there
Yeah - you're gonna be a little mad for the next couple of weeks as I remember ;)
At least it won't matter too much on the drive thru France, as you won't be listening to the radio I imagine...
