Ceri1980
I posted on here last week as my Xenon headlmap isnt working (Drivers side, main beam). I ordered a new unit as it had to come complete with gas chamber but its still not working!!
Any ideas what it could be????
Thought it could be the fuse but when i checked I couldnt make out what fuse it could be....bit confusing for a girly like me!
Really fed up of this now! :think:
Its actually dipped beam (what i call main beam!).
Not side lights, the next one.
The lighting fuses are in the engine compartment, but I think the lighting circuit is split left/right. So if it was the fuse, the whole of the drivers side lighting wouldn't work.
Could possibly be the ballast unit.
If you follow the bulb wiring back from the bulb/ignitor, it should connect to a box. This is the ballast.
I haven't actually seen the layout of factory xenon headlmaps, so I don't know where the ballast is positioned.
The ballast for OEM xenon lights is on the bottom of the light unit, it would be a bumper off, light out job to access it unfortunately.
