Problems with Dashboard Lights, Help Required
jjelmes
Hi sorry to jump in with such a title but having used the search function I discovered these guys have suffered the same problem with dashboard as im getting with a 02 reg leon 1.4 16v eng code axp, problem is all the lights on dash including illumination flash & a buzzer sounds one short beep then one long beep over & over when the engine is off & key removed, all this goes back to normal if you either (a) start the vehicle or (b) turm on the lights (side or head) have read all the threads but none of them reach any conclusion, Im hoping someone can help me, many thanks in advance, jeff, newbie.
Tony Marshall
Any luck?
I've got the same problem on our 1.6S Leon (52 plate). Found a thread on here that suggests checking earth connections - I cleaned three earth connections up under the battery - it seemed to be okay overnight, but back to 'normal' later the next day. So I thought I was in the right ball park, so had another go today - no better.:(
Any ideas..?
jjelmes
Thanks for the reply Tony, the problem is still ongoing with this car, only thing found so far is that the carpet / underlay was absolutely soaking wet because of what turned out to be a water leak from top of bulkhead where main wiring loom comes through on drivers side under wiper motor, its a known fault apparently so I fixed that but the problem comes & go's, I did notice when I had the front striped out there is an ECU under the front windscreen / vent by wiper mechanisem in the centre that looks to me to be very exposed, dont know if this or maybe another ECU has suffered water damage, any updates & I will post, regards Jeff
PVROSE
jjelmes and Tony Marshall
Did you get any resolution after your latest posts in December 09?
I have the same problem - see my posts in name PVROSE.
If you guys solved it - how?
Thanks PVROSE
Tony Marshall
Peter / Jeff
I left the battery disconnected (as usual..) during the icy / snowy weather last month - couldn’t use the car for the best part of a week - then found the problem seemed to have resolved itself when I reconnected…!:)
Relating this to a pilot friend, he told me that they use freezing to reset the 'firmware' in certain aircraft systems when needed. This is sort of hard-wired software in the micro-chips. Quite how this cures it, I don’t know, but it seems to be okay now.
I was just thinking the other day I would come back and report on this site, but I didn’t want to count my chickens too soon..! Still, fingers crossed, seems to work now okay.
The depressing thing is that I took the car to a Seat ‘specialist’ in November, who charged me £90 to diagnose that it needed a new ‘dashboard insert’ for £500! I had my doubts and subsequently tried cleaning up the earth connections under the battery (there are several), which I found suggested somewhere online. This seemed to work for a day or so, which just coincided with me getting a ‘quality assurance’ questionnaire from Seat. As you can imagine, I gave them a piece of my mind… As you might expect, I heard nothing in response….:censored:
As for the solution, it may be the fact that I had left it idle for many days in sub-zero conditions that did the trick for me, when it seems not to have cured yours. Not sure if we are going to get such cold conditions again, but it may be worth a try if we do. Or maybe you could find a frozen food company with room to park a car in their freezer… Alternatively, with the help of your local mechanic, maybe you could remove the relevant microchips and pop them in the freezer at home.
Good luck – I’ll let you know if it recurs (probably tomorrow, now I’ve said all this..!)
Tony
PVROSE
dash lights
Tony
Thanks for the reply - I hope you are now OK
As I mentioned in the reply I put on the other jjelmes thread, my problem STARTED after a week of frozen non-use!
I`m going to try a few more things and will report if anything seems to help.
My usual garage couldn`t help (though they did suggest unplugging and replugging the main dash cluster connection but I haven`t been able to get to that yet). I was also cautious about SEAT dealers because I have never got out of one at under £300 whatever I went in for - it is easier for them to just replace everything and charge accordingly.
Thanks again & good luck
Peter PVROSE
jonners67
flashing dashboard lights and buzzer
Hi all with the problem of flashing dashboard lights and warning buzzer. I think ive got the answer to all your problems. Its a company called BBA Reman in Rochester, Kent.I removed the dash took it to the chaps at BBA Reman who disected it and said there was an illumination fault, it was repaired and back in 4 days cracking service.
3 weeks down the line and silence when i get out of my car fantastic!! :clap::clap::clap:
PVROSE
dash lights and buzzer
Congratulations - most people (except me) seem to solve the problem one way or another.
Rochester is rather far from me. Did they elaborate on `illumination fault`? A bad connection or tracking in the dash array always seemed to be the most likely.
Thanks for your message.
Peter PVROSE
