Is this engine variable valve timing ?
Car in for service & cambelt tensioner recall, I mentioned that the drivability is poor at low speeds, and turbo wastegate noise, dealer says timing was out, I thought this was all monitored adjusted by ECU ?
BTW also having high level brake light replaced as it weeps, dealer says part has been modified as known issue.
There also investigating jumping gear lever when reverse selected, will keep you posted.
