Question? Can i get my turbo accuator wound out a bit
Leepey74
Question?
Just a quick one,
Can i get my turbo accuator wound out abit more to produce more turbo boost??
Also will it damage the turbo?
Regards
Lee
Apr 28, 2003
2,624
If i was u leave it where it is, Ie factory position on a non chipped car there is nothing to be gained but trouble by altered the waste gate, if u want more power for cheap get an upsolute chip from impossible.:cheers:
prc
Sooty Meister
Originally posted by jerry
can someone explain what exactly winding out the turbo actuator is???
I'm explaining it in a tdi point of view, but the idea is the same for petrols as well.
Basically but winding out the valve, your going to get a bigger initial spike in boost pressure. It takes just an extra bit of time before the actuator closes the vanes on the TDI vnt turbo. On a petrol it would be the wastegate ???.
BenS1
3,459
West Sussex, England
My understanding is that if you wind the wastegate a bit then it changes how wide the wastegate can pen when set to full open. So if you consider the normal full open position to be 100% then if you wind the wastegate up 10% then the max the wastegate can ever open to would be 90%, meaning you are still getting a little boost.
So, by winding the wastegate you are effectively making it so that the ECU can't throw away all the boost even when it wants to, thereby giving you a litle more.
Personally I would say stay well away from it. Let the tuners do the tuning.
Ben
prc
Sooty Meister
Ben
Sort of sounds right for a petrol, but I'm not sure. On the vnt turbos (tdi's) you'll get just a little extra boost before the accuator starts moving the vanes.
Tall-Paul
Previously ph2858 :D
Nov 12, 2006
671
Manchester and Preston
I know this is an ancent thread but ive been doing some searching on actuators as this is what my new boost gauge is supposed to connect to, so my question is....Where is the actuator on an 03 ibiza tdi 130pd? Cheers
