why is that were the OE ones you mentioned do?
the ones i have changed have mostly tapered at some point
Why dont you fit the S3 one. Plug&Playand its quite cheap.
im getting a 25mm rear and 23mm front, not keen on really beefy ones just personnel preference I suppose.
at RuddWhy dont you fit the S3 one. Plug&Playand its quite cheap.
Actually, the difference between 25mm and 28mm (we are talking rear?) is quite noticeable, even on the road.
28mm being too stiff IMHO, 25mm being just right. But Ruddmeister and I have agreed to disagree for about 4 (?) years on this, that he WRONGLY says 25mm isn't stiff enough.
Everyone's entitled to their own, albeit incorrect, opinion.
at Rudd
Have you though about those new ones JBS are doing - they look quite good, although with them being hollow they might be stiffer than a solid bar (if my memory of torsional stiffness and bending moments is correct).
So would a bigger bar at the back create more or less understeer?
the one difference Phil is at least you (like me) have driven a variety of modified LCR's hence it's an informed opinion we have rather than guesswork.....
