DDX
does someone know if they would fit (maybe some work?) ?
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=150037243360
Sorry i was, i forgot about the new one!
I looked at the german ebay sites too as theres a few sets on there but logistsics etc put me off
think they move electronically with out that wired up you might not be able to adjust the seat position. nothing a little custom wiring couldnt fix though.
I reckon that would be a great little project getting them fitted!
Just swap the side sove so the driver will be sitting in the passanger side. Go to audi get the plastic that hold sthe switches and swap over the bits! job done.
Ive had my recaros apart twice now and an electronic s3 recaro, it seems simple enough to just swap them over
The vast majority of VAG parts are interchangeable between different models and varients. I don't see much difference in the runner design so should be able to fit. Getting the powered bits to work may be harder if the current wiring under the seat doesn't support it.
Golf Mk4 R32 seats are a straight swap. Golf MkV or RS4 seats will require a certain amount of fabrication to get them to fit, if they will at all. I suspect the base will be too wide personally.
