ekjambo
Dave Cowie
Oct 5, 2011
49
East Kilbride
Evening folks,
Got a rather irritating issue with the Toledo(had it since day 1 tbh) that I'm hoping someone can help with.
The reception through the radio is GUFF!! Now granted 75% of the time I listen to my iPod but sometimes you just wanna stick the good ol wireless on but it is no use! Its always sounding as if its not receiving a strong enough signal.
Would the nice wee 'bee sting' ariel that on the car be the route of this or something else?
Help would be appreciated! cheers
D
Not that it helps you much, but I've heard this is a common problem with the Toledo and I suffer the same. Sometimes its fine but other times I receive nothing, whereas my old Astra would normally get a reasonable signal most of the time. I have an aftermarket stereo fitted, and am not certain I connected the amplified aerial correctly; though I don't know what else I could have done.
If you have an aftermarket stereo you need a power supply for the aerial base. Its the size of a spliff and plugs into the rear of the stereo and powers the aerial base via the coax cable. They're made by Autoleads halfords / ebay
The base itself could also be faulty, I had to replace the base on my Octavia
so....I've just taken out the radio to fit the booster cable and discovered that there is already one fitted :wtf:
My next port of call is to swap the aerial out for a standard one off my mates ibiza...fingers crossed!
Some are different than others, some have 2 connectors for radio and satnav? the mast screw threads are different sizes
this is what I came across when I took the stereo out...the one I got from eBay was very similar with a blue wire rather than green.
I dot think my v5 had satnav as it's only a single din space on the dash...my mates "beefa" certainly doesn't
My octavia doesn't have sat nav but my aerial was dual satnav and radio. My base was faulty and I replaced it to find the mast didn't fit due to fiffering thread size.
Just a heads up before you fit, try the mast in the thread.
Swapped the aerial from my mates ibiza onto the Tolly...readio works fine! Seems there is a wee small (about 5mm) 'plug' on the end of the aerial that the bee sting doesnt have :(
Now to find me a standard aerial to replace it with :think:
I will have to try one of those adaptors as i have had the same poor reception with my aftermarket head unit.
Bought an adaptor for £5 from halfords back when the world cup was on last and it was rubbish.
Halfords are only good for their occasional offers.
I avoid the place like the plague now.
But good topic i will have to try this fix. Any other success stories?
my signal is rubbish and i have the standard equipment fitted,would the problem be the same?.thanks
