ben20VT
Newbie
May 26, 2004
37
Hello,
I have order a Raid HP maxflow (the same as ram air MF103), and I come to you for some informations :
- which size of breather filter do I need (13mm, 16mm or 19mm) ?
- do I need an other cold air induction hose to go to the front of the car ? (I don't know the original hose longer given in the kit ...) And if I need one which longer and diameter ?
- with this system do you see more vibrations compare to green twister ? (that's for MAF i ask that ...)
thanks to help me
Ben I think the breather filter you need is 25mm.
I found the RamAir better with a cold feed from the bottom front
