jwmurdoch85
82
Maidstone, Kent
Hello,
My Mk4 Tdi 130 sport has developed an odd random fault (happened 3 times now)...
Basically when arriving at the car (could have been left for any amount of time ranging from seconds to hours!) I find that the instrument console only (not the radio) is lit up with the red back light (the head lights are switched off - I've checked that), and when attempting to restart the car it goes into safe mode and will not start.
There is a whole load of random faults when scanned by the garage and they are not sure where to start with it, as it seems like the car is having quite a paddy, although it is saying that there is a mis-communication with the dash insert (could be a clue)?
It did this again on Saturday and it smelt like someone had been soldering in the cockpit - not good.
Has anyone else experienced this or able to offer any advise that would be gratefully received!
Do a search on immobiliser problem, I'm sure you'll find you 130 TDI is particularly prone to dry joints on the back of the instrument panel, especially if you've got the 6 dial dash.
Its a 2003 (03).
Bondiblu - just come across your thread, the guide looks good for getting the dash panel insert out. I assume the burning smell could be one of the joints failing? Is there any issue on the length of time the insert is out of the car for? I.e would it need re-coding?
John
hi, I had it out several times, didn't need recoding and had it out for ages when I did the soldering. As long as the connector is re-fitted back properly, it should be fine. Disconnect the battery first!!! Was totally spot on till I got rid of it, so definitely sorted my issue out.
Update - Dash Panel Insert Removed
Right...
Finally got round to removing the dash insert as this problem continues, and my findings are that the joints for the connectors are fine :D but...
A cluster of surface mount components look like that they are failing, lots of discolouration and burning smell. Photos of damage as follows:
Obviously this needs sorting, and I've had some hideous quotes from stealers just to look at the car despite the fact I can tell them whats wrong.
Is any one able to offer any advice on my options?
Is it worth trying a scrappy? If this is an option does the dash insert need coding / activating using any special tools?
Thankyou for any advice
John
cluster
hi, i have a simular problem with the cluster going wrong but not as bad as yours, it seeme to be a commen problem on the 6 dial clusters, mine doesnt click on indictation and fuel guage stoped working.
dont get another cluster, u would need vag.com and varius codes for the immobiliser, not sure if thats dealer only for those codes.
Look on the net for ecu repair, 2 examples i had quotes from:
bba-remain - £150 + vat to repair
ecu-testing - £175 + vat to repair
send ecu to them normally week turn around
tom
