Rear brake pads
Drew1
69
Burton on trent
Hi I’ve just replaced my rear discs and pads and my handbrake ain’t as good as it was, could it need bleeding or anyone got any ideas thanks cupra r mk2
Legojon
I only wanted a remap
5,084
2,540
If they were really low it might need adjusting. If they needed bleeding I'd have thought you'd have travel in the pedal when braking as well.
Reactions: fozzybear
elnigel
217
10
Chesterfield, Derbyshire
Handbrake should be better and have slightly shorter travel initially with new pads on as they are thicker. Could be due to pads not being bedded in yet.
Have both cables been connected back up properly at the callipers?
Sent from my Moto G (4) using Tapatalk
ZiggyEP3
405
72
UK
If all assembled back up it should self adjust the handbrake once the reservoir cap done up and brake pedal pumped till a firm pedal feel is there. With the brake fluid topped up the handbrake on mine didn't need adjusting by me when i did the 4 discs and pads. Until the discs have had a bit of use bedding in they wont be at 100% and the discs will have an anti rust coating to scrub off by braking yet.
