Rear caliper piston
aterro
Banana Bomber
Oct 28, 2009
118
i was removing my pads on rear then saw piston
usually you would just g clamp it in on most cars.
so i started using this http://www.eurocarparts.com/ecp/f/p...Service-Tools/Brake-System-Tools/?SEAVS024&0&
and the piston is still solid.
the car passed its mot 3 weeks ago so the piston isnt ****ed? hope not.
any ideas?
i feel like im not using the tool right now.
my handbrake is off.
and my clyinder top is off.
i still have my other rear caliper on.
aterro
Banana Bomber
Oct 28, 2009
118
erm. about 4mm?
the piston does move as i have slightly tryed the break pedal to see if it does move.
aterro
Banana Bomber
Oct 28, 2009
118
nope. doesnt even move. i carnt even move the end of the piston tool even with a longer arm on the end
Feb 26, 2009
5,275
Wolverhampton
I had the same problem on an mr2, took some serious effort and wheel brace on the end of the tool to get it moving.
Same here, I needed to give it a fair bit of encouragement to get it moving. The little bar was useless, I got a proper ratchet wrench on it with a suitable socket. The ratchet also helped with winding it in as I could keep a rhythm going.
I did find not jamming it tight against the caliper got a good start, then once it's moving tighten it up to apply pressure. You almost have to get it spinning before you push it in? And I had to occasionally 'slip' the tool, it was almost as if the thread on the tool was at a higher angle than the piston thread, so every so often it would just lock up.
aterro
Banana Bomber
Oct 28, 2009
118
just sorted it.
just put some wd40 round the edge
and alot & alot of effort and a 19mm ring spanner round the end the little arm.
and it slowly started to move.
happy days.
thanks lads
