Rear Footwell Leak
Nigel Chamberlain
22
Hi all.
I'm new to all this.
I've just brought a Seat Leon MK1 1.9 TDI. (Lovely car) however with all the heavy rain we have been having I have noticed that I have a leak in the rear passenger footballs on both sides.
Can anyone please help?
T.I.A
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Common problem.
Can be a few things.
Can be the door hinge mechanism.
The rear light cluster
Or the door seals themselves.
Badger5 Custom Map + TIP,
Nigel Chamberlain
22
Common problem.
Common problem.
Thank you for the reply.
Il have a check on these tomorrow. Sounds abit silly but what am I looking out for (I'm new to all this)
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Signs of water ingress.
If you have a hose. Soak the outside then open and see which parts have become wet.
If on the door sill etc it’s the door or hinge.
The seals inside the door cards perish and need replacing. Sometimes it’s been bodged with the likes of kitchen sealant.
There are thousands of guides on how to do the door seals.
Sent from my iPad using Tapatalk Pro
mty12345
3,772
477
bristol
The holes are there, they are just often difficult to find. The first pic is of the seal, the second pic is looking down inside a stripped out door.
This is the kind of sealant you need. https://www.ebay.co.uk/itm/HIGH-PER...a=1&pg=2334524&_trksid=p2334524.c100667.m2042
Nigel Chamberlain
22
All 4 doors now have clean drain holes. All the day 2 day crap all blown out with a air gun and seals all cleaned with brake cleaner. Then car washed with a industrial jet wash and by the looks of it no leak. :)
Reactions: bigT's lcr
mty12345
3,772
477
bristol
Unless it's been sealed with the butyl, then chances are it will still leak even with the drain holes unblocked mate. i will keep my fingers crossed for you though.
