GTV
Veggie powered TDi's
Feb 16, 2008
479
Cambridgeshire
I had nighmare day and to top it off rear bearing gave up the ghost on the way home and almost put me in a river.
Anyway I have removed the nut and washer from the drum (no small job) but as the bearing has gone big time I can't get the remains of the bearing or drum off so has anybody got any ideals, also it looks like the stub axle has the thread dramaged at the end so how do you change that?
cheers for anyhelp as always (just as I fix one car the other one plays up ahhh)
once you strip the backplate off the stub axle comes away bolt on job
if you are shopping for one make sure you ask for 'drum' type as the caliper is a different shape to bolt the caliper on to it
chock the front wheels, jack it up, take the wheel off, let the handbrake off then as you turn the drum tap it with a hammer, but try and pull the drum towards you as you do it.
ok got it off in the end, I need a stub axle and key washer
does anybody know the part numbers and an idea of price? where would be the best place to get them from is it back to the main dealers?
