Hi, Im trying to order a set of rear brake discs and pads off of vwspares.co.uk. Now the rears are 256mm vented right? but what are the pads, the same as the rest of the range as indicated on the site or should they be different considering the disc diametre is larger?
I was going to be cheap and buy the febi dot4 plus fluid which is £5 a litre as ive been unable to get Castrol dot4 plus on trade at halfords recently so should i give this stuff a go? (car is generally not given a hard time and never tracked)
£76 for the lot does sound a bargain at the moment as ive easily been quoted double that for O.E. Kit
Adam
Adam
