Rear screen demister.
RobDon
Pro Detailer
Is there any way of fixing broken elements of a rear screen demister? I've tried the usual conductive paint stuff which didn't work. Other than 'accidentally' breaking it and having it replaced through my insurance is there any other way?
Dopedpanda
"Old" Hardcore Ford Fan
Jun 15, 2013
172
Denmark
Are you sure you have used the conductive paint properly? Most cars you have to scuff the existing heating elements a little up before you get a good contact through it.
If that doesn´t work, its new window time.
RobDon
Pro Detailer
I tried that Granville stuff but by all accounts it is garbage! Will try other stuff before I get the glass replaced as that is a last resort, but it's 4 lines right across the middle of the screen which is mega-annoying!!!
martin j.
1,997
894
Fife
I've just used the Granville"stuff"on mine and it worked fine, Icouldn't find the instructions(very old bottle) but read the back of a box in stock at work, it says leave to dry for 5 hours before switching the screen on!, did you follow this?
RobDon
Pro Detailer
I left it overnight after giving it a couple of coats. I taped off the lines, coated all the breaks I could see on all 4 lines twice, left overnight in the garage, took the tape off the next day and it didn't work on any of the 4 lines.
AlexK1
545
Poole
I've used an official Renault kit in my work before, done the trick. I'll see if I can find a part number on it and whether it's the same as the Granville product. It came in a rather small nail varnish looking bottle with a white plastic cap/brush.
I'll have a look when I'm back in on Monday and let you know what I find
AlexK1
545
Poole
Here's all the details I can get, part number is on the bottom. Can get it from your local Renault main dealer. Hope this helps!
Dopedpanda
Jun 15, 2013
172
Denmark
Hi, sorry to say, but it aint gonna cut it just taking the visual route. You need a LED 12 lamp or something to follow the current. You turn on the demister, put the negative end of the lamp on some ground on the vehicle, and then just trace along the line from one end to another. I have done multiple repairs where the cut isn´t visible.
AlexK1
545
Poole
Yeah there wasn't one in the kit I had. I just used two strips of masking tape to line it off
Dopedpanda
Jun 15, 2013
172
Denmark
When i use the kit from renault (i work at renault) there is a brush down in the solution like a touch up paint.
RobDon
Pro Detailer
That's what I'll be doing, masking tape, just seems odd that the kit tells you to use the stencil and there isn't one in the kit! It isn't really even a kit, just a bottle of conductive varnish. Yes there is a brush attached to the lid.
AlexK1
545
Poole
Yeah I know I had the same when I used it at my work. But there wasn't a stencil listed to go with it, masking tape done the trick when I used it.
Fingers crossed this works for you!
