Rear sidelight issue, prefaclift FR
DanDiesel
In my diesel is where I'll be, chugging merrily.
Mar 17, 2005
169
10
Kent
So yesterday, a bulb out warning light appeared on the dash. Got to work, left car running and checked everything. When I got in the car to turn it off, the light had gone.
It came on again on the drive home and turned out to be a n/s rear sidelight. No problem, easy bulb change.
Anyways, today came to change the bulb and it didn't work. Changed the orientation as they are W5W bulbs and still nothing. So tried another one and still nothing. The bulb holder for this light contains the reverse light bulb and this is working fine.
Tried the two new W5W bulbs in the sidelight that works and they are fine (incidentally, the old bulb is indeed naff). Checked the wires and they are all connected tightly into the connector.
So, I'm pretty confused as it seems only half the bulb holder is working. Anybody have any ideas what could be the issue?
DanDiesel
Mar 17, 2005
169
10
Kent
Could only see a bit so cleaned it off. Swapped around the bulb holders and then neither side light worked so swapped them back and voila, both now working!
So, solved but still confused lol
