Rear Spacers.
CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
Today I fitted my rear spacers and they are great, but theres one problem. I have a rubbing noise now.
It isnt the wheel bolts against the hub, it sounds like its inside the hub.
Thing Im thinking is that its with the handbrake being on tight to stop the hub etc spinning when tightening up the bolts or with everything being torqued up when re-fitting.
Any other suggestions.
Craig.
CraigW
Craig.
Apr 12, 2007
4,607
I could really do with some help with this guys. Been out again and there is still a rubbing. And as the car is running it seems that the handbrake is tighter when you go to put it back on.
The spacers are 20mm and the bolts to bolt them to the hub are the same length as the wheel bolts I was running before. Im :confused:
CraigW
Craig.
Apr 12, 2007
4,607
The wheels arent touching the arches. Its like there is something rubbing/catching all the time. It isnt all the time though. :confused:
I dont want to take them off because they make the car look good. Its like the brake shoes rubbing.
Please someone help me :cry:
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
Moved to the DarkSide
sounds to me that the bolts are rubbing against or are forcing the rear brakes to bind slightly???
I personally would take them off befroe driving anywhere, and then see if i could get a few mm taken of the bolt length?
Sep 20, 2006
756
Birmingham
Did you have spacers before? The new bolts should be longer than the standard ones.
