DanLewis1991
183
Newport
which spacers make the wheels fill the rear arches the best? is it 25mm?
and what is the best make? hubcentric?
if i was to put the 25mm spacers on, and lower it 50mm on the standard wheels, will there be any rubbing?
The 20mm ebay ones everyone goes for will look great and you will have no rubbing issues. Not sure about 25mm though!
Might be interesting to do something different. Just make sure they are hubcentric spacers though (ones that have the correct sized spigot/hub diameter - 57.1mm if I remember correctly!) so they sit snuggly on there and don't cause any wobble or bearing issues!
Yeah 20mm will be fine and those ones posted would be fine, but I still don't trust spacers.. Never have and don't think I ever will.
It's better to (when you decide to) change your alloys and go for an offset like ET38/ET35 and then they will sit well in the arches.
is it worth getting the h&r ones? they are super light but cost twice as much. i only have a 1.2 so any extra weight is a no no lol. advice? cheers
