Ted64
17
7
Hello again,
Does anyone know how to remove the rear wiper blade on the terramar and what Bosch blade to replace it with? I ordered a Bosch A282 H but it doesn’t look like it will fit and I can’t even figure out how to remove the existing blade- there is no little button to push on the housing to release it!
Hello again,
There's an installation video at this link, titled "Easy Rear Wiper Install"
It looks like it's for Formentor but I believe they use the same arm.
Reactions: Seastormer
I have tried the Bosch A282 H but it definitely doesn’t fit!
Measure your old blade, I believe it should be 280 mm (11"). If not, check the table below to find the one with correct size.
Bosch seems to be recently released some new rear wiper blade packaging that includes multiple adapters, each package has 4 different clips. Check to see if any of those may fit.
Why not try the forum sponsor @COX Motor Parts. They list the OEM part number on their website as 57895542703C and it may be more expensive than the Bosch A282H but at least it should fit. @COX Motor Parts also offer a discount to forum members;
Link to the rear wiper blade on @COX Motor Parts website below. It states on the web page that they will also check (using VIN or Reg No,) it’s the correct blade for your car once you’ve ordered.
