Refurbing Your Brembos: For Dummies
greck999
SLOW work in progress....
Jul 10, 2009
396
Rugeley, Staffs
I found that if you mix a bit of black hammerite with the red it will be a good match as the standard red hammerite is too bright and 'orangey' in my opinion.
Just mix a small amount in a small pot and you will have enough for touching up. ;)
welchy
I done mine with hamerite spray I didnt use any lacquer IMO you don't need to.
How did you prep your calipers pal?
Did you fully strip them down?
Deleted member 12147
I rubbed them down, just enough to remove the original brembo logo and remove any deep scores, then sprayed them.
I done my rears on Saturday with the paint not the spray. They turned out ok but I'd definately recommend the spray over the paint.
I used a 70mm brembo decal and didn't lacquer over it.
JamJay
California Bound
liam_91
Thanks :D did mine today and im chuffed with the results, look 100x better!
greck999
Jul 10, 2009
396
Rugeley, Staffs
Did mine yesterday with the red hammerite spray and they turned out really well. Chuffed to bits with the results.
What i do suggest is that if you are laquering make sure the hammerite spray has gone hard and not "almost" hard as one of mine was when i decided to laquer on the decal.
It reacted with the red hammerite and went wrinkly like a old scrotum.... :wtf:
Which i had to take right back and do again..... :censored:
The decals that JamJay recommends are good enough and look spot on.
just have to do the rears to match now....:)
Jun 16, 2008
516
sounds like a plan,
does anyone know how much new calipers would cost though? just curious....
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
Wow - refurbing my brembos seems like a distant memory now LOL. Been so long I think they now need a proper respray before they can be considered to be like new.....
Dyscontinued
1,142
Leeds
The amount of time I've owned the car and put this off...finally got around to it, wish I'd done it ages ago!
Relaquered mine the other week, look great, would look fantastic if I'd bothered to repaint them too.
Before
After
Wheel on
rydogg09
lcr ry
Feb 5, 2012
403
Doesnt the wet and dry sand paper rub the paint and brembo off though? Sorry if being dumb, cheers
Dyscontinued
1,142
Leeds
I didn't use sandpaper. I just literally pealed off the flaking laquer, cleaned the brakes using soapy water and sprayed laquer back on.
rydogg09
lcr ry
Feb 5, 2012
403
so what about the laquer that is still ok? did u get that off or not? ior can you leave that and apray over? cheers
rydogg09
lcr ry
Feb 5, 2012
403
did it not show tho where the new laquer meets the old, u reckon its best to take it off? and guys what is the best laquer to use?
