jonesnips
Was driving home and smelt like an electrical burn, after spending some time at home I returned to my car but it refused to start. I believe that maybe my fuel pump relay has burnt out and that would explain both the smell and the non starting; can anyone please either come up with some other options that would explain both the symptoms and also has anyone got a link to a diagram of the layout of the relays and fuses!!!
get urself a haynes, got mine off ebay for like 6 quid when there 15/18 in shops lol. will help you out with alot of things.
would tell you the number of the relay but seems as i am at work and dont have it with me lol i cant sorry
however, if you take off your glove box (one under the drivers wheel) it should say on there what relay and fuse is what.
but about the symptoms i havent a clue i would have thought its either the fuel or there is no spark.
Your car may have a later fuse box, but mid 80's to early 90's looked like this in a VW.
thats the fusebox only know a few, relay 8 is the wipers, fuse 22 (10a) is stereo and lighter socket, fuse 21 (15a) is the boot light and central locking(
Dunt know if these are of any use:
1. http://www.a2resource.com/electrical/electrical.html
or 2. Pre 90's fuse box detaills
Fuses
Fuse No. Description Ampere Rating
1 Radiator cooling fan 30
2 Brake lights 10
3 Cigar lighter, radio, clock, interior lights,central locking 15
4 Emergency flashers 15
5 Fuel pump (gasoline engines) 15
6 Open -
7 Taillights, parking lights, side marker lights (left side) 10
8 Taillights, parking lights, side marker lights (right side) 10
9 Headlights (high beam, right) high beam indicator light 10
10 Headlights (high beam, left) 10
11 Windshield wipers/washers 15
12 Heated seats, electric outside mirrors 15
13 Rear window defogger, heated inside rear view mirror 15
14 Heater blower glove box light 20
15 Back-up lights, automatic transmission console light 10
16 Horn 15
17 Knock sensor control unit (gasoline engine) 10
18 Dual horn, coolant level and temperature warning light 15
19 Turn signals, brake warning light 10
20 License plate lights 10
21 Headlights (low beam, left) 10
22 Headlights (low beam, right) 10
Relays
Relay No. Description
1 Open or Digifant relay
2 Fuel pump (gasoline) / Glow plugs (diesel)
3 Seat belt warning
4 Upshift indicator (1985-1987)
5 A/C relay
6 Dual horns
7 Open
8 Load reduction
9 Open
10 Intermittent wipers
11 Rear wiper
12 Turn signals, flashers
13 Open or power windows
14 Cooling fan after-run (except 16-valve)
15 Passive restraint (1988, 1989) or ABS/coolant temperature relay
16 Idle air stabilizer
17 A/C thermofuse or ABS
18 Coolant level indicator
19 Power windows
20 Heated seats (left)
21 Heated seats (right)
22 Oxygen sensor system power supply (US cars w/CIS) / Automatic transmission relay
23 Power window fuse (30A)
24 Glow plug fuse (Diesel-50A)
List of relay numbers / descriptions:
1 = Carb inlet manifold heater relay
2 = Fuel pump relay (MK1 & Early MK2/Rocco K-Jet)
5 = Shift light and MPG gauge
15 = radiator fan
17 = x-over relay, 40amp?
18 = x-over relay
19 = front wiper intermittant relay
20 = rear wiper non-intermittant relay (when you push the stalk forward, it'll only wipe once, no intermittant!)
21 = hazard/indicator relay
30 = MK3 (GTI 8v or 16v?) ECU relay
32 = MK2 digifant ECU relay
36 = seatbelt warning relay (possibly headlight warning too?)
53 = misc equipment ignition switched relay (horn, fogs, leccy windows etc)
67 = MK2 16v/ MK3 VR6 fuel pump relay
72 = rear wiper intermittant relay
74 = carb decelleration cut-off
80 = MK2 digifant fuel pump relay
99 = front wiper variable intermittant relay
109= VR6 ECU relay
133= aircon relay
167= MK3 & MK2 16v fuel pump relay
or 3. Post-90 Fusebox Fuses & Relays:
1 Headlight, low beam, left 10
2 Headlight, low beam, right 10
3 Instrument panel lights, license plate lights 10
4 Glove compartment light 15
5 Wiper/washer 15
6 Fresh air blower 16-valve only: Air conditioning 20
7 Taillights, side marker light, right 10
8 Taillights, side marker light, left 0
9 Rear window defogger 20
10 2.0 16-valve only: Fog lights 15
11 Headlight, high beam, left,High beam indicator light 10
12 Headlight, high beam, right 10
13 Horn 16-valve only: Radiator cooling fan 10
14 Back-up lights, washer nozzle heaters 10
15 2.0 16-valve only: Engine electronics, stabilizer valve, cold start valve 10
16 Instrument panel warning lights, 16-valve only: Multi function indicator 15
17 Emergency flasher switch, turn signals 10
18 Fuel pump, oxygen sensor heater 20
19 Radiator cooling fan, air conditioning 30
20 Brake lights, cruise control 10
21 Interior lights, digital clock 16-valve only: Luggage compartment light,multi function indicator, central locking 15
22 Radio, cigarette lighter 10
Relays
1 Air conditioning
2 Open
3 Digifant control unit (except 16-valve)
4 Load reduction relay
5 Low coolant level control unit or Open
6 Emergency flashers
7 Rear Wiper
8 Intermittent wipers
9 Seat belt warning system control unit (possibly headlight warning too?)
10 Fog lights
11 Horn
12 Fuel pump (except diesel)Glow plugs (diesel)
13 Radiator cooling fan after run (except 16-valve)2.0 16-valve: Starter interlock relay
14 Automatic trans., coolant temperature indicator,starter interlock relay (except 2.0 16-valve)2.0 16-valve: Radiator cooling fan after run
15 ABS pump relay
16 ABS relay
17 Heated seat control unit, driver
18 Heated seat control unit, passenger, or power seat circuit breaker
19 Automatic transmission
20 Open
21 Power window relay, ABS hydraulic pump fuse
22 ABS valves fuse
23 Air conditioning, power seat fuse
24 Power window fuse
Im thinking its probably something in the engine bay burning out, have a good look around see if there are any signs of burning. Particulary battery connections, ignition coil, alternator.
Ive heard of people have issues with the fuel relay but no one has ever mentioned the burning smell.
If nothing, check the fuses and relays. To be honest if you smelt it that strongly i would expect a sign somewhere.
5 Wiper/washer 15
Relays
1 Air conditioning
2 Open
7 Rear Wiper
10 Fog lights
11 Horn
15 ABS pump relay
16 ABS relay
20 Open
22 ABS valves fuse
That one looks right to me
hello does any one knows about seat altea 2.0tdi fuel pump relay location the car stopped itself and i have put on machine just says fuel pump relay
Hi does anyone or can anyone look at there fuse box and tell me where the main power and earth go into the fuse box?
odd question i know but im using a seat ibiza gti 16v 1997 fuse box in a project and forgot to take note of were the power and earth go into the fuse box
any help much appreciated matt
does anyone know which number relay operates the central locking system ? would be of great help
seems that the relay is engergising when the unlock and locking buttons are pressed on my key fob, does anyone know where the master switch is located for the central locking system?
Deos anyone have a pic of where the ECU relay (relay 30) goes? I took it out last week for someone to test on their car and now i can't remember which position it goes in the fuse box.
Hello,
The indicators on the drivers side (right) on my 2004 Toledo saloon are staying on all the time. I suspect its a relay but anyone know where the relays are ?
Seagull out
