Hi all.
what boost pressure in psi are your remapped LEON CUPRA R's running??
mine peaks at 25-26 and holds 24 sometimes 22 depeneds on what gear and if you load it up like.
so what sort of boost pressure does your remaps run etc and can you UP the pressure more than a stage 1 as i think standard for a lcr is 14? and up to 22 peak and hold low 20s? so what is achieveable etc/
