I took my car down to Bill at Badger5 on Wednesday to have a stage 1 remap. The car dyno'd std at 174bhp and about 255 torques iirc. It was over boosting at this point by about .2 bar, which is apparently a common thing and he had seen it before. First map we tried on the car, I think it did a 199 with 313 ft/lb, 2nd and 3rd run I believe it went into limp mode. This was just using fueling and torque limiters I think he said, Bill recommended I did a vnt clean, we had a look on the Internet, and one of his mates had a video up, basically he took the turbo off, stripped it and cleaned the individual parts until the vnt's moved freely. I had a quick research on here, and bought some revive turbo cleaner, ran it through today, following the guide and not a lot has really changed, I also fitted a boost gauge (problem 2) which has told me a couple of times today that the boost has gone off the gauge, it's an auto gauge 30 psi gauge. Which is above 2 bar!! In the end, Bill put a map on where he just added more fuel, it achieved 186 and 279. Noticeable difference, but I wasn't hoping to go there and potentially have to take off a turbo, then pay for more of Bill's time. Obviously this isn't his fault, he did the best he could given the situation, and could have saved me a few pennies in the long run! Does anyone have any ideas what other things could cause my over boosting? The car is as follows, straight pipe, egr delete and Jetex cone. Recently serviced, and inlet was cleaned when I did the egr delete. My plans are now, to take off the dp and spray mr muscle into the turbo, and if this doesn't make a difference I'll take it off fully and do a proper clean. I would really appreciate anybody's input/opinions because I need it sorted by march really.
Problem 2 - the boost gauge I have fitted clicks as it climbs in psi, and down again. I think it may be because I've used the egr feed that comes with the delete, so ill be down to b and q tomorrow or a plumbing place to source another tap, or a nut to use the existing egr pipe thing. There is a video on YouTube of a golf mkIV with the same problem, and he has also used the egr supplied tap, what makes me think this is that every RR I've read the owners have used a boost pipe to acquire the pressure, I'll update tomorrow with my findings about the relocation of the source, if not I will be complaining to halfords, and getting it replaced. They can think again if I'm undoing all my work though!
Cheers for any help, Josh.
